1HZ H55 install kit to FJ40
crushers
post ho
Derwent Alberta
Morning,
I have been receiving numerous requests for the 1HZ/HDT install kit.
Figured I can save all of us some time by posting a thread here and in the FJ40 forums. (if that is allowed.)
All prices are in USD, prices are increasing 10% April 2nd 2023.
Shipping is not included. I do have access to decent shipping costs but I can send packaging size and you can source your own shipping.
These parts are designed to be used in conjunction with each other. if you decide stray from the install instructions ... shug. don't whine.
there are dozens of kits out there now so as long as your model is 1969 - 1978 these part are proven to work.
You can also us the kit for 1979 to 1984 40s but the rad mount will need the mounting holes modified to work with the factory recievers.
I have heard that the cross member is different in some of the pre 1969 models, you might need to modify to work.
IF you have a kit and have issues I will try to help. wayne@crushersrule.com .
here we go
all parts are high zinc primer with matte black top coat Powder Coating.
All bolts are yellow zinc chromate where possible.
This kit works only with 1HZ, HDT, HDFT coupled to H55 transmission. If you wish to use the R series tranny that is your choice. The R series does not work well in the 40 series, nor the H150, H151.
The instruction manual MUST be followed.
Other custom parts might be offered in the future as requests are made.
this is the basic kit you will need to install a 1HZ/HDT H55 into a 40.
$ 214.88front engine mounts not powder coated
$ 451.14transmission mount with weld on plates including bolts (rear engine mount) powder coated crossmember
$ 436.75Fan shroud including bolts powder coated
$ 247.24Rad Support including nuts powder coated (1969 to 1978 application)
$ 69.56Over flow bottle with lid (over flow setup will not work with AC pump. Interference)
$ 196.59Modified New Engine Insulators including nuts (for both)
$ 135.96Transmission Insulator including nuts
$ 243.94Fan Clutch including nuts shorter mount to allow for more clearance between fan and rad. (will not work if running AC)
$ 128.11Fan including bolts less offset to allow more clearance between fan and rad.
$ 196.27130 amp / 150 amp alternator mount with belts including bolts powder coated
$ 288.64Fuel filter mount with cap, filter and sender powder coated mount including bolts
$ 215.45Below body battery mount with lid and top floor reinforcement plates to clear up engine bay powder coated
$ 212.65AC compressor mount with pulley and belt for the vintageair AC FJ40 kit including bolts powdercoated
$45 Kick panel speaker mounts. Allows for kick vents to still be functional, powder coated.
$35 USB/volt/lighter mount plate for radio slot powder coated.
$35 Electric locking switch panel powder coated for switches and lights and anti theft switch. Switches extra. Wiring diagram included if switches and lights are ordered.
$3900.00Mapped turbo kit. Includes new turbo, manifold (with usable exchange), new factory HDT crossover pipe, SS hoses, fittings, gaskets, adapter. All exhaust side parts are ceramic coated. Dump and first 2 ft of 2.5” pipe with SS flex pipe.
Shipping is extra.
installation manual included in the engine and tranny mount.
each piece is designed to work as a kit.
each part has been tested to work properly.
the mounts MUST be installed within 1/8" or 3mm of instructions.
Nice looking parts.
shipping for full kit is 6 x 11 x 32 - 27 lb, 26 x 27 x 6 - 31 lb
Just when I’ve got the ole 1F buttoned up and limping this comes along. @HemiAlex thanks for the heads up.
@crushers Beautiful bit of kit.
thank you
the F engine is a sweet powerplant. reliable, tons of grunt.
I assume you've totalled up the cost of a full kit? Maybe post that vs making everyone pull out a calculator?
