All my turbo testing is done towing.....wait for it..... up to 9000lbs but it weighs 6100lbs empty and can carry 1100lbs of water alone! I realise this exceeds the manufacturers vehicle ratings, but its my truck and risk and more than 30,000kms has been done on current engine in this config.
look at Offroad Caravan Hire in Perth | Bushtracker Hire to see the caravan - thats my website
Ive just returned testing the new Grunter 2 at up to 30psi for 7200kms. My goal is to stay in overdrive down to 80km/h (1600rpm) up most hills and never go lower than 20:1 AFR's.
I use the caravan because it is real world conditions and on a long hill gives a better idea on safety of tune, reaching design goals etc. The same on a typical dyno will overheat the dyno (that has ben my experience).
So, as far as engine performance and long heavy hauls, I believe that know what I am talking about. Now, I used a 100 series on this trip, but the same is true for the 1HDT in an 80 or 100 as I have used them all.
The owner of Bushtracker is an American fellow and drives F250/350 Dodge Rams etc etc and won't sell a caravan bigger than mine to a Landcruiser owner, but mine out pulls a 7.3 F250 easily! The last hirer of my van had a mildly chipped F250 7.3 to which he showed me a dyno printout (230whp if I recall correctly) and I took it for a drive with van in tow. I was really surprised how lacking it felt - I was expecting a while lot more for all the massive exhaust noise! I am glad I have a boosted 4.2 Toyota Diesel! Oh, the economy was at least 10% better as well. I tow at 100km/h up and down hills, mostly in overdrive but not possible up some. Never outside of 1:1 gearing above 1600rpm (4th on manual). With no wind, I use 18-18.7L/100km as measured by fuel bowser andy GPS.
Pre turbo EGT's that are safe vary a lot from say 1800rpm to 3000rpm in terms of what is safe. I have pre and post EGT probes. Factory from Toyota you will see 750C pre turbo on a long haul.
As far as damage to factory turbo, I would like to say that the damage is twofold:
*overspeed (the biggest problem) - comp wheels fly apart
*boost wearing thrust bearing and damaging the oil seals
So, adding an intercooler and 3" exhaust means that at the same boost setting the turbine rpm is higher at a given engine rpm. So, from an overspeed perspective, the stock comp wheel is in a more dangerous condition on an intercooled and big exhaust mods compared to same boost on stock exhaust/no intercooler.
The boost level aspect is thrust pressure and that is simply boost related.
FYI, Im trying high flowed injectors in the next few weeks - that will be a first for me.
Dougal,
you and i have been down this road in the past ...
we will agree to disagree.
until you are willing to replace peoples trans then those numbers are an unwise suggestion to agree with.
he will tow what he feels comfortable with.![]()
