As bling as this looks, how are you going to access the lower bolts on the joining flange.
welcome fellow troll
Welcome fellow 1HD-FT owner!
Still trying to find someone who can make custom fuel lines for the right price. Thought of using brake line but its out of the question even though it can handle 3000 psi, the constant hammering would kill it eventually.
This is more my speed, just trying to find someone in straya that can do it.
http://www.rocken-tech.com/Fuel_Lines.html
Off topic and lovin it![]()
Talked to buddy with the hopped up 1HZ
Running 35lbs of boost (gturbo bb2), big front mount, custom airbox, custom plenum, 12mm 1hd-t pump getting 240rwhp on 35s....
He is also putting meth into it now, sounds like fun!![]()
The numbers check out (using 280hp crank), but unless he's dropped a lot of compression I'd be awaiting the
The numbers using a VE of ~70%. Wouldn't you expect higher from a custom plenum?
BTW, a 1HD-FTE with the same fuel and boost would be delivering about 50hp more (330hp crank).
Yep, he's running 1 of my airbox's. The plenum deisgn still isnt the greatest. But the figures look good.
Yeah mate that's without the meth. Meth still needs a bit of fine tuning. Gets a bit if knock going on when it comes on flat out
Can this be cured with a slightly less advanced or agressive IP timing?
Nope. Because the meth is present before anything gets injected and simply isn't stable at diesel compression temperatures.
It honestly is one of the worst things you can do for a diesel.
Have you explained this elsewhere in another thread Dougal, or is this your first comment on meth injection. Just looking for info here....
