I originally posted about this on 11/20 but no replies were received. I have some new information.
I have verified that as long as the center differential lock (CDL) is engaged that the noise and engine revving doesn't occur. I believe something is slipping in the driver's side front wheel area. Here is what happened the other day: as described below, I was driving it again and the engine rpms shot up and was accompanied by a loud whirring noise in the front, I let off the gas and engaged the CDL and the revving/slipping was controlled, I could feel it start to slip and then I could feel the CDL sending power to the rear driveshaft and the engine wouldn't rev up and I was able to continue driving. This was repeatable. When I was almost home, I disengaged the CDL and a few moments latter, when I was coasting (foot off the accelerator pedal), the loud whirring noise started and then it changed somewhat to a skipping/grinding noise. I pulled into my garage and stopped with the CDL still disengaged and my foot off the accelerator pedal and on the brakes ... there was a slower (no revving) rotating grinding/skipping sound coming from the front driver's side wheel area. If I engage the CDL it stops.
I don't understand everything from the transmission to the wheels but it seems that something is slipping between the front driveshaft and the front driver's side wheel (not in the transmission). I haven't had time to take anything apart/inspect anything yet.
It seems that the front "half shaft" with the boots would be splined on each end and the only thing I can come up with is that the male or female spline is worn and allowing one to skip/rotate relative to the other (it seems this could cause a loud grinding noise like I'm hearing) but I've never heard of wearing out a spline drive. Having said that, I can't think of anything else that could cause this but as I mentioned I'm no expert.
Has anyone ever heard of either of these spline interfaces wearing to the point of slipping/skipping teeth? Any other ideas on what could cause a loud noise in the front, and could allow the rpm to rev up when the CDL is not engaged?
Thank you!
_______________________________
Original Post:
Engine appears to rev up with light throttle, loud whirring noise in front
Discussion in '100-Series Cruisers' started by Ironman2011, Nov 20, 2016.
1999 Land Cruiser - no serious off-roading in its life but has 237k miles.
About 2 months ago I was driving at 75 mph or so on the highway and a loud noise seemed to come from the front left (driver side) and the tachometer shot up to ~ 4k rpm with no vehicle speed increase. I let off the throttle quickly and the rpm dropped (but my heart rate didn't) then reapplied the throttle easily and everything seemed normal since then. Today, the same thing happened several times while driving 30 to 50 mph. It sounds like a mechanical whirring sound that really gets your attention. Immediately after I let off the throttle and eased back into it today, I tried accelerating relatively hard and it didn't slip or whatever it is doing when it makes that noise. But then if a few minutes it would rev up under light load. I thought that since in a normal rear wheel drive car power is sent to the wheel with the least resistance and since the sound seemed to be coming from the front that if I engaged the center diff lock that the engine wouldn't rev up since half of the power would go to the rear wheels. I don't know if my logic is sound but it didn't do it again and I was able to get home. (I didn't want to engage the center diff lock since I was on clean drive pavement but I didn't want the engine revving up either and didn't want to limp home at 5 mph and back up traffic for miles so I tried it).
I haven't checked diff fluids or anything yet.
Our joke in the car was that it was an expensive sound
:-( I'm scared.
Any ideas?
Thank you.
Ironman2011, Nov 28, 2016
Thank you!
Original Post:
Any ideas?
Thank you.
