- Thread starter
- #381
They are original seats from a low mileage donor.The interior looks amazing, did you use OEM seat covers?
Ty!
Do you have a bit more detail on that @SNLC? I'd very much like to make this change on my 80 with the 1HZ engine. My old LN106 hilux had a mod you could do where you swapped the oil cooler housing from a Coaster and it made the filter mount vertically from the bottom, which meant no mess. I hate how messy changing the filter is on my 1HZ. Do you have to change out the actual copper cooler element inside to fit the new housing, or is it as simple as putting the new housing on with the bracket?You also need the correct oil cooler. The little cup below the filter doesn’t mount to all oil coolers.
Cheers
I got it from another cluster I had in my spare box.Where did you get the blank gear shifter indicator?
