Looking forward to seeing what it looks like with the bumper style push pins. I think I probably would powdercoat with a semi-matt light color that works with the interior, if it were me.
Not sure if you have one of these or not. They work pretty well getting OEM door panels off. Nice work on the door cards.
Amazon product ASIN B000NP2SBG
Dude, so sorry. This bites hard. Hopefully damage is minimal.
Awwwe man! I hate it when stuff like this goes wrong/sideways... especially when there are so many other things vying for your time and money.
It's odd as in the earlier pictures, that spacer appears to be the same size as the hub and the rim seems to sit further back on the hub itself
I have never worked with the manual hub kits, so I have little to offer you as far as guidance. Perhaps John from Radd's can give you some definitive solutions. I realize this probably sounds like a pat answer, and would likely earn me a solid punch were I to say something like this in the moment, but after I calm down and get past the initial disappointment and kicking of my own @$$, I try to look at it as a learning experience, something to add to my repertoire of know how to either help someone else or for the next time I have some work to do in the same place down the road. You just always hope that the 'lessons' are not tooo expensive.
Sorry for the troubles my friend, hopefully John can steer you in the right direction... no need to start talking planter boxes just yet.... hang in there.... from your previous posts, I can see you have the talent to make it right.![]()
If it was me, since it looks like you have a full mini truck axle, Id just swap the whole knuckle over from the mini truck and be done with it all. That axle is built for manual hubs so it will all be ready to roll with no adjustments. If you don't have a full axle, then some good sealent/plug for that wire hole (re use the wire plug?) and get the mini truck spindles on. No more spacer needed and ready for manual hubs.oh no yea I'm fine, just self deprecating. I have made some epic blunders in my time, I'm 100% confident this will not be the last one.
what I'm wondering is.... I was comparing the mini-truck solid axle spindles to 77 electric locking ones and they are exactly the same except a slightly different bearing race taper setup. although where the bears sit it's exactly the same OD. so... I have this spare axle assembly, yep everybody needs a spare axle assembly. it has full built out chunks for a solid axle pickups. I could use them and the spindles. so I know that would probably work. There is a notch in the 77 electric hub setups in the knuckles for the wire. not hard to plug that up. But I still need the plate adapter to make up the difference in space for these axles. so... not being able to take the wheels off the truck without taking the entire locking hub/plate off is not something I want long term.
I like the electric hubs just for the uniqueness of them, but I definitely understand the concern for reliabalilty. So I am collecting parts slowly for a swap in the future lol.
It’s also nice that you have I believe FJ60 rotors already in the mini truck hub. Factory they were all solid rotor rather than vented so you are ready to roll! Although you might be able to have just swapped rotors as well. But those bolts tend to be a huge pain so if you don’t have to, just get them turned on the vehicle (better anyways) later and call it a day!yea and I compared everything side by side. slight variations due to rust and wear I would guess but I think it's exaclty the same.
the pickup have
rotor to wheel mounting surface 48.88 mm
wheel mounting surface to hub face 60.32 mm
the 77 electric hub
rotor to wheel mounting surface 48.45 mm
wheel mounting surface to hub face 60.68 mm
obvious to me now the spindles are different because of how the bearing lock nut works. DOH!
77 hub left, pickup right
what is even better is the 77 shares calipers with the Toyota IFS pickups. nice! I tested the fit and yes the pickup solid axle chunks are perfect fits without the need for the adapter ring. so, this is how I will roll it seems.
I do need to source a couple of brass bushings and some new gaskets but that is it for now I think. fire parts cannon sir! yes fire away.
Ok full stop on the golden hub club.... I should have done a test drive before I posted... I'm guessing I maybe missed a detail someplace? and it does not appear as though these were intended for 77 series electric locking hub replacement?
first problem that I did not notice? you can't remove a standard size hub bore Toyota wheel without removing the ring. The ring itself is larger than the bore so.... I think this is a deal breaker. having to disassemble the entire hub to remove a wheel is not a great design.
the other part is totally my fault I should have maybe considered looking a little more closely? at how the wheel bearings nut locks in place. the inner most ring of the electric locking ring has those 3x little torx bit screws. they engage with the wheel bearing lock nut to hold it in place. I'm familiar with the solid axle pickup truck hubs where you have those tabs you bend down so... I kind of figured the wheel bearings were actually locked into place by the same deal. I figured the inner electric locking ring on the setup was just to clearance those screws to hold that ring. I was wrong.
that is the wheel bearing lock nut and it locks via the next picture, that ring.
those torx screws line up with the holes in the lock nut and the tabs slide into the groves on the spindle. so this is the locking mechanism.
But what happened during my very short test drive of course is the wheel bearing nut unscrewed. It was really subtle however but I quickly returned at snail’s pace the couple of blocks and started to cry as I realized how stupid I had been.
I don't think it messed up the axle, but it for sure made a small mess out of the end of the spindle. so, I will have to pull the entire chunk now and see what is what.... not sure how the kit will work for this setup. I'm guessing the kit will not work what so ever with the 77 series electric locking hubs and you have to source a totally new knuckles/hubs/spindles? I don't know I will have to talk to Rad Cruisers?
You're trying to second guess a kit that's been around a very long time and the dimensions are very exacting - this kit was designed specifically for these vehicles - the 77s, and 78s etc.
Your wheels are the oddball part here. They little bit that protrudes in is oddball, and they are either not factory, or are and add-on item that your 77 did not come with.
And, you removed the bearing adjusting nut locking ring - which is the slip ring in these vehicles - which is not something the instructions say to do. You have to really understand the system before you remove the parts.... It NEEDs to stay there.
I will add a note to the instructions explaining this as it's important to know how to adjust these bearings and to understand how they are retained.
Thank you for bringing this to my attention.
~john
Same wheel and same issue for me. The ring was slightly larger than the hub. Ended up taking the ring down carefully with a Dremel. Not ideal but plan to convert over the manual locking knuckle/spindle eventually.Yes I fully understand how it works now with the lock ring. This has nothing to do with the kit. agreed.
the stock hub OD as I measured with a calipers is 105.35 mm. the adapter ring OD is 106.35 so the ring is larger than the standard hub OD. if the OD of the ring matched the stock hub it would be fine for me.
The wheels are Toyota part 42601-35751. These wheels are for a 5th gen 4runner. The wheels fit on the 77 hub just fine without the ring. so to me it's the rings that are oddball.
Now that I understand it's really just a standard toyota pickup knuckle, spindle, hub I see no reason to continue to run the old spindle, hub. Had I known this I would have never gone the kit direction. But now I know.
for me being able to run a hub or lug centric wheels is a requirement.
for people who do not want to swap out the old spindle/hubs and run lug centric wheels it's a great choice. It just might be important to mention this so future confusion is avoided.
Heck yes, now we are cookin with gas! Great work!while waiting for parts...
the 77 electric knuckles have that spot for the wire so... now that I'm ditching those spindles... I could just gob FIP into that spot... but a much harder more expensive path. exists. perfect! To answer the first question no it does interfere with the inside. The stock spindles have a huge electrical box in that spot.
3d printed a plug to fill the void. will still have to FIP into that spot but this should be a lot < FIP.
used fusion 360 to create a mold from that plug object. works pretty good, have done this a couple of times now to create custom polyurethane bushing for suspension and body mounts. I think the hardness of the material I use is 90 nits? it's good stuff. has made it thru multiple MN salt filled winters and it's still looking good.
View attachment 3243895View attachment 3243896
