Next up was legroom. I’m 6’5” so the seats really don’t go back far enough, which is true on a lot of vehicles, but particularly bad on the 70 series.
I decided to extend them to see how much it helps. Well, it helps a ton. This was a rough test, so it’s not very pretty.
I used 1” box tubing from Ace hardware. It was $12, Probabaly can get it cheaper at a metal place or scraps. $2 in bolts.
I cut the box tubing to 17” long.
The center to center on the seat bolt holes is 13”.
I made another set of holes 2” back and put a larger hole on the bottom so that a socket would fit to tighten to the seat. Also you need a cutout for seat adjuster, again it looks terrible but works on The prototype.
All holes lined up the first time. Make sure to give some wiggle room on the holes, even the factory has some room for error.
My ARB compressor is mounted under the seat. It’s pretty quiet compared to some of the other ARBs I’ve had.
Ideally I would like the have the back of the seat lower, but it’s pretty comfy as is.
1” higher and 2” back makes a pretty nice setup. You can see the comparison to the passenger seat.
Yes those are my extra Jetta floor mats. It’s a TDI so it’s ok.
So for less than $20 and about an hour of work, highly recommend and well worth it for us taller folks.
