SOLD 1987 Land Cruiser FJ60
Year
1987
  1. 60 Series
Mileage
373054
Color
gray
_daily driver for ten years : passes safety inspection: wipers, tail lights, signal lights, emergency brake, e-flashers
_drives quiet, new clutch smooth- 4w ok
_overall looks good and is reliable currently - high mileage - priced according
_consistent maintenance last ten years; oil change by mechanic ( not jiffy lube) on engine every3500/tires rotated
_recent maintenance and repairs by LandCruisersNW, PDX, OR, an excellent shop
__heater works well, rear defrost works
BODY
_Color: dark grey exterior, interior original grey upholstery. noticeable >is a streak on passenger side from neighbor kids (seeimage). Dent Doctor estimated repair at $ 50-100. Hood has dark grey bed-liner layer coating.
_Carpet is original, worn as expected but not torn
_Upholstery is OEM grey color - faded as expected -only rip is side of drivers seat
_headliner in good shape - some smudgegs- not ripped or torn
_back seat OEM is in storage - not in images
_rear window hydraulics work but are weak if temp below 40 degrees: replacement $35 each after market option at O’Reillys
_new windshield Jan 2025
_lifted 2015 ( Old Man Emu kit )
_windows work but stiff
_dash has a crack, is covered with custom fitted cover - see image
_needs horn
_tires - All Terrain - good tread left - warranty with Les Schwab.
_vehicle has been in AZ and Central Oregon high desert most of my ownership - some rust
_has elec for trailer signals - installed by licensed electrician
_custom design safari rack optional - used value + - $400
_leak under window started recently - priority body repair !!!
_ 2022: replaced: hood release cable
RECENT MAJOR UPGRADES ( OEM parts) installed by PDX Land Cruiser specialty shop- see under hood photo
2023 extensive tune up : distributor cap, rotors , spark plug wires, plugs PCV valve and frommet, air & fuel filter, oil, oil filter
2024 transmission replacement (married type), input, main seal, flywheel resurface,split case rebuild kit, new clutch , transfer case rebuild
2025 new radiator, radiator accessories, thermostat, water outlet gasket, radiatorhoses, aisin fan clutch, master and slave cylinder
I have to let it go after a decade plus of cross country and back country trips.
Still use it daily - at 373,054 miles obviously a replacement engine will be needed at some point. Asking 8K
I am not getting all my investments back - it's how these rigs go - it's been a great, safe ride. Clean title. Good to go
Hey - nice looking 60 series. Do you have pictures of the underside? Looks pretty good for that vintage.
BODY
_needs horn
Canceling sale. Disregard. Thanks
