Parting Out 1986 FJ60 - Northern NY
Bavaria
Picked up this 60 a little over a month ago to pull parts for a manual swap for my FJ80. It's in rough shape otherwise, lots of rust, but hopefully there are still some parts on it that others can use.
Unavailable parts:
Transmission
Transfer Case
Bellhousing
Clutch pedal assembly
Lock out hubs
Both Front and rear passenger door cards
All AC vents
Seatbelt receivers
Cigarette lighter
Headlight washer bottle
EDIT: No LONGFIELDS
EDIT: This 60 is also lifted. Those are 35" tires. The springs are, per the PO, OME. They do have heavy surface rust on them, but they could easily be refinished.
If there's anything you're looking for or need better pictures of, let me know.
Thanks.
I'd be curious about the long fields and how much you wanted?
Is the original radio intact/functional?
I'll be up in Potsdam next week but no way I can divert over your way - I could be interested in the complete f/r axle assemblies....
If you are the fronts would be complete minus the locking hubs. Rear axle I don't need at all.
Where are you located? Could help with getting them to where they need to be.
Open on prices. I'll be peaking into the front to see if the Longfield rumour is true.
How's the Front passenger seat cover?
Actually I'd also be interested in the Passenger side washer bottle and pump if it's still in good condition.
