- Thread starter
- #21
I'll PM you some pictures tomorrow once everything is pulled.I'd be interested in the t-case boot also.
Id be interested in the driver's side front rain gutter trim piece if undented. also interested in the outer a/c dash vents the ones that open and close. just turn them sideways and pull them out.
is the headlight washer bottle (driver's side front fender) unbroken?
How's the Front passenger seat cover?
Actually I'd also be interested in the Passenger side washer bottle and pump if it's still in good condition.
If you mean the black pieces that cover the nut on the post, there are none.I need a windshield wiper bezel or 2...
pm'd you regarding price on theseRain gutter has some small denting and light surface rust. Dash vents are available. Washer bottle looks good. I'll check for leaks when I pull it.
Both are there; one is intact, the other has a broken clip that holds it in.no, I mean the finial at the opening of the cowl; looks like a banked donut...
Not sure what those are? If you got a diagram or something, that'd be helpful.Is the large diameter air cleaner breather hose uncracked? also is the hot air tube that come up underneath it still there? pm me with prices if they're good
Checked quickly as its raining out. Hot air tube is there. Appears intact, but it's buried under everything.the hot air tube is circled in red and connects to the underside of the air cleaner arm
have you got any sun visor clips?
and last query before request to purchase...how are the front side marker lights? gaskets intact? TY
