Builds 1979 FJ40 Preservation-ish Project (8 Viewers)
Unscheduled rear brake job!
I plan on fully addressing the axles at a later date. Adding a rear air locker to a semi float axle will probably suck!
Wow, having cold A/C is a complete game changer!
Fortunately you only need a/c for a couple of months in North Florida / South Georgia. 😁
The main reason I eliminated the oil cooler was because my York a/c compressor bracket makes accessing the oil cooler hose impossible, without removing the a/c compressor, alternator and bracket, and that require removing the radiator, radiator shroud and fan clutch.
@wngrog said I could.
The main benefit is that I can more easily access the fuel filter and adjust timing.
My original brake booster is failing now that my brakes and master cylinder have been replaced. I should have just replaced this with my master cylinder.
I am guessing break fluid from the master cylinder is a contributing factor to my failing brake booster.
