Awl_TEQ
Supporting Vendor
- Thread starter
- #781
......., only this one was on the road!
Ouch!
Haven't touched it other than I mounted a 315/75 R16 with 4.5" back spacing just to try and decide what tire to go with. I keep waffling back and forth from 33x10.5 to 35x12.5.
33" I can use my stock splits (which I would like to do) but I feel there is a 90% chance I will just end up wanting 35" tires after a short time.
Trouble is 35" tires will pose quite a few challenges with clearance.
1) I will need new rims to get less backspacing. I could buy Procomp rims with 2.5" backspace to push the tire outboard and that would get me enough room to hit the steering limiters where they are set now at least. The pitman arm will still hit the tire though.
2) I will also need more lift. I have already bought a Dakkar 2.5" spring set..... which is not enough for 35" tires. I could extend shackles. Not my first choice but I can laser cut my own anti inversion units to suit and reuse the pins etc from the set I bought. I would weld in a bit of rectangular tube between the plates to stiffen the shackle up. Or buy a new set of spring$.
3) The 35" tires being 12.5 wide will also stick out about 3" past the sheetmetal. This brings up a minor local legal issue of tire coverage and may require some sort of rubber fender flares. Also the rear tire would no longer fit within the wheel well and therefore will decrease the flex allowed at the back by several inches. I am building my own bed and as such I could enlarge the arch in the bed side by about an inch in diameter before structure stops me.
Anyway... here are some pics with a borrowed tire - 315/75R16
This is with the axle on a jackstand and a scissor jack pushing the worn out stock spring down a few inches. I have no idea where my new springs will put the wheel but hopefully about here.
This is with the axle on a jackstand and about 800 pounds in the bed - stock old spring. In this positin there is about 3" before the bump stop hits so in theory it could flex up another 3".
This is the same orientation as the above pic but showing the tire protruding. This is a 4.5" backspace wheel so a 2.5" would stick out another 2".
