After looking at that t-stat housing and stuff I think I would remove the radiator, water pump and all hoses. Get the radiator Rodded out, new t-stat, hoses and new water pump and all new hoses. I had a similar cooling system issue on my redneck 40 and it is easy to do with the bib off. Also the guy that did my radiator cleaning gave me some stuff in a bag to run and clean out the crud in the block. Good luck with your build.Any advice on flushing this out?
Hey, congrats on bringing this heritage 40 back to life. I think you need to consider doing a full acid flush like seen here:Any advice on flushing this out?
Moving fast. Keep up the good work and don't lose steam!
I think that might be the same antifreeze that was in it when you sold the rig 20 years ago!
Awesome. I was thinking of a flush like this. 3 gallons of muriatic. That is gonna raise some questionsWe have a bit of a meth problem in east TN.Hey, congrats on bringing this heritage 40 back to life. I think you need to consider doing a full acid flush like seen here:
Little help: flushing coolant / engine block...
That block is REALLY bad and you're going to have ongoing issues with it if you don't seriously address it. Nice Shepherd too, I've got an all black one from near Holland, best dogs ever.
Nice. Looks like the red with white trace still has a bare spot? When you get around to pulling the harness out of the tub, I'd suggest firing up the VOM and checking continuity. Old wires have a habit of corroding inside the insulation, they look good from the outside, but are blue powder on the inside (been there...).
Definitely look into that. Thanks!!Cat makes a cooling system flush that works really good
Can find it at heavy equipment suppliers
Last stuff I got right from Caterpillar
I have a question about fuel tanks. In the not so distant future I will be welding the floor back in. Im gonna go with real steel panels most likely. The panel for the fuel tank is a really deep press and Todd offers a patch that you cut a hole for and then weld in place. The factory tank is 16.4 gallon capacity while most of the poly tanks I have seen are 12.5 gallon. Is this reduction in capacity due to the reserve section of the steel tank (depression) not being present on the poly tank? If so if I used a poly tank would the depressed patch be necessary? I cant find any pictures of the underneath on a poly tank.
Thanks for the advice!Can't answer your question but seems like most on here say to avoid poly. OEM is still available...
