Builds 1977 FJ40 “Larry the LandCruiser” build (1 Viewer)
Florida, United States
This is the beginning of my thread for my 3/1977 FJ40 named “Larry the LandCruiser”. This first post is going to be a bit lengthy as I go into a bit of the background.I’ve included some pictures of my grandfather washing Larry in North Carolina in the 80s, me at a car show in 2024, a photo shoot I did in 2025 and the original window sticker.
Originally purchased brand new by my grandparents in August of 1977 at Trail Toyota in Punta Gorda, Florida for a sticker price of $5,950.82 and now Larry has been in my family for almost 48 years at this point (I’m only 25 😂).I have a lot of the original documentation including the window sticker, sales receipts, import documents etc. This will be a collection of what I do and some things I have already done while he has been in my ownership.
My grandfather really enjoyed owning Larry he had many vehicles during his life but always kept Larry around but unfortunately passed away in 2008 due to cancer. My aunt and uncle then got Larry and kept him in driving shape til around 2016-2017 when he was parked in my grandparents garage and there he sat until 2023.
In 2023 I was gifted Larry as my 23rd birthday present and at first I had no idea what to do. I have 3 2006 Dodge Ram trucks with the 5.9 Cummins I’m more familiar with diesels but an inline six is an inline six it can’t be that complicated 😂. Over time I found the great people here on Mud and was able to slowly figure out what I needed to look for before getting him started for the first time.
Luckily he was parked and sat for 6 years with an empty fuel tank. I added new gas, primed the oil system and put in a new battery. Had to pump the gas a few times and he cranked for a while but he started and I was amazed to say the least. I only let him run for a few seconds then shut it off and went to get my grandmother to show her. I didn’t plan on it being so easy to get him going. She had the opportunity to see the beginning of Larry coming back in full force and that was a great experience as she was one of the original owners.
I backed him out of the garage and took a lap around the yard and at that point I was hooked. After that I did a full fluid change and drove him around for a while with a weeping water pump I later figured that one out before anything bad happened. In November 2023 my grandmother and I went to a Cars & Coffee event and it was an awesome experience to have her there interacting with people as they came up and asked questions about Larry. I could tell them about his history and she would tell them about memories she had when he was new. That was also the first time I had ever seen another FJ40 in person at that event there were 2 others.
This experience made me want to continue working on Larry and going back to what I said previously I didn’t really know where to start. At that point the first thing I did was attempt to clean the cooling system which for me was just cleaning the over flow bottle and me thinking everything was okay. 😅 That would lead to me doing the water pump, thermostat, new coolant & hoses, BVSV and eventually the radiator.
I plan on updating this thread as time goes on and hope others stop by and enjoy checking in on it.I have put about 2,000 miles on Larry in the past 1 1/2 years and during that time I’ve replaced the following:
Cooling System: Radiator, cleaned up radiator support and replaced canvas shims, water pump, thermostat, all new hoses, BVSV, heater valve, cleaned up the fan shroud
Hydraulics:Clutch master & slave cylinder, brake booster & master cylinder, stainless steel brake line & cutch slave line.
Lighting: OEM Toyota semi sealed bulbs (best $17 ever) resealed the tail lights and replaced the bulbs
Spark: Spark plugs, plug wires, distributor cap, rotor
Cluster: Odometer wasn’t working so I disassembled the odometer took apart the mileage tracker and lubricated the assembly. The old grease turned to glue essentially not letting the dials turn to track the mileage.
Weatherstripping: Front doors, ambulance doors, & kick vents (less rattles 😂)
Charging: Interstate battery,heavy duty cable set, cleaned up battery tray, new hold down & canvas shims,new fusible link, alternator & voltage regulator were replaced during previous owner ship and I have original
PCV: PCV valve, PCV hose
Fuel lines: In cab soft lines and lines to fuel separator including new check valve.
Suspension: 4 shocks
Misc: Vaccum lines, VTV, air filter, air cleaner intake rubber section, fuel filter, all fluids, updated drain plugs to 10mm hex, greased chassis, hubcaps, pedal pads, cup holders, belts
My grandfather washing Larry in the 80s
Me at a car show in 2024
Photo shoot in 2025
Original window sticker
Great backstory! Im sure this will be a very rewarding project for you. But we are going to need way more photos of your 40 inside the engine bay, interior and the exterior! We love photos of 40’s around here 😁.
Nice story and rig. Looks like you’re done with your build. Good as it sits. Hope to hear about the open road.
What a cool story! Glad that the 40 stayed in the family and will continue to do so. I'm also glad to see a younger guy working on one of these old rigs! Most guys your age can't even drive a manual at this point, let alone have the interest or capacity to turn a wrench. Great stuff!
I actually figured out how to drive manual in Larry the LandCruiser and he has the original clutch still. Only 42k miles. I figured he sat untouched for about 6 years now it’s time to make sure that never happens again. Luckily these trucks are relatively easy to work on.
My biggest obstacle that I run into is not having someone knowledgeable about the platform I can have conversations with when I have questions. Doing the work is easy finding the procedures on what to do can be tricky for me.
Thanks for taking the time to read it! I plan on posting more pictures soon. I have pictures of most of the work I’ve done already and plan to get more soon.
I actually figured out how to drive manual in Larry the LandCruiser and he has the original clutch still. Only 42k miles. I figured he sat untouched for about 6 years now it’s time to make sure that never happens again. Luckily these trucks are relatively easy to work on. My biggest obstacle that I run into is not having someone knowledgeable about the platform I can have conversations with when I have questions. Doing the work is easy finding the procedures on what to do can be tricky for me.
Thats a great story. Its sounds like Larry is in good hands. You come to the right place. The folks on this forum will gladly help with any questions you may have . At one time or another everything has been covered. You can checkout the clubhouse section too. You may find some folks that are local to you.
I will post some pictures of car shows/trips I’ve been on as well as the work I’ve done. 👍 thanks for taking the time to check it out. I greatly appreciate it!
Looks like your grandpa loved that thing!! He is getting elbow grease in, not just “holding a hose and hoping it gets clean”
Yes Mud has been very helpful. I’ve found some people that are somewhat closeby like RetroFive and another guy I can’t think of his username of at the moment. Yet to meet up and talk but hopefully someday. Thanks for stopping by and taking the time to comment!
He had many vehicles during his lifetime easily over 40. He even had steam engines, dragsters, tractors pretty much anything with an engine 😂. The only vehicle he ever held onto was Larry. All the others got traded or sold for money to put in other projects. I think it met something special to him as he bought it when him and my grandmother were newly married and before they started a family.
Random pic (2003) I’m 3 and Larry in the back.
Awesome story, photos and cruiser! Very cool - I love the patina :) Hard to find like this. Enjoy it.
Thank you the patina is my favorite as well! I polished the original paint and it cleaned up well. I hate when people ask, “When are you gonna paint it?” He’s all original and I like it 😂
The time my grandmother and I went to Cars & Coffee November 2023: There is a local Cars & Coffee event that has a good turnout and I decided to take Larry to his first outing after getting him started after sitting 6 years. My grandmother tagged along and it turned out to be a great experience. It was about an 80 mile round trip and this was the first time Larry had been on the road in 6 years. I will say thinking back on it I don’t think I would’ve done that now I know the condition he was in from sitting but he was a champ and made it no issues.
A lot of people came up and talked to us about Larry and they enjoyed the fact he was a little rough around the edges. After talking to people for a little while i walked around and found 2 other 40s at the show and met the owner of a tan 40 named Dave. We talked for a while and exchanged numbers then the show wrapped up. That fueled my excitement and I wanted to see what I could work on that day when we got home.
When I got home i figured I would take a look at the vaccum lines because they were from 1977 like most everything else at that point. In doing so I broke the nipple off of the VTV and the hunt for parts began. I was able to make a temporary fix at the time because I want sure I was able to find the correct VTV. I ended finding a used one from CruiserParts after a few weeks. This would lead to me replacing all of the vaccum lines when I replaced the broken VTV
Perfect - I love that you are replacing vacuum lines and getting it dialed in. There is nothing better than a stock 40. Yes, modified ones are cool too - but I've always enjoyed cracking open a Toyota service manual and what is indicated is what I have under the hood, down to the vacuum line. Enjoy this time. I remember this well. So fun.
