my brake proportioning valve is stuck so i decided to disassemble and clean. i was able to take the nut off but not sure where to go from here. any advice appreciated.
Note: This feature currently requires accessing the site using the built-in Safari browser.
thanks.Check this out
Proportioning Valve photos Disassembled
I took my proportioning valve apart because the rear drum brakes were locking up before the front discs. After cleaning all the rusty looking sediment off the internals, and brushing the inside of the housing with a brass shotgun brush, the brakes are much more reliable. Still not sure how it...forum.ih8mud.com
thanks.
i actually saw this; however, per my photos, i dont see the spring and other parts in mine
gotcha. so should i just order an oem style from cityracerllc in your opinion?
Thank you so much for this information.The two rubber parts (piston seal and u cup seal) are available from muscle car research.
Other Products | Muscle Car Research LLC
www.musclecarresearch.com
Could you give an update on whether those parts fitted? I have a 87-89 (non-US) proportioning valve which may need re-sealing. Thanks.Thank you so much for this information.I just ordered these parts. I just couldn't stomach the idea of $90 and up for this simple part.
I used them for my valve.
Proportioning valve restoration
I obtained this a while back (thanks @65swb45) Tore it apart and cleaned it out, replaced the piston and u-cup seals with the kit from Muscle Car Research. Cleaned up the rusted end caps, tried my hand at home Ni and Cu plating (Instructables.com), I think they turned out pretty good...forum.ih8mud.com
