Ackcruisers
- Thread starter
- #21
Not yet. I’ll try that over weekend and report back.
@Grayscale …I just got off the phone with the electrical engineer at Performance Tool. There is a known issue with the W2972 digital automotive multimeter. It will not provide accurate dwell or tach.
Thanks for everyone’s help on this.
I‘m in search for a reliable multimeter that has tach and dwell capabilities…
Curious about this, where are you reading this?I’m going to leave it there as I‘ve read more about dwell angle on the 2F engines and it apparently matters little for a low rpm motor.
1) It’s ported on the base of the carb. I set RPM’s with the hose attached.
Few questions:
1) are you running ported vacuum or manifold vacuum advance, and is the idle at 650-rpm set with vacuum attached or plugged?
2) does the 2F FSM have any references wrt when the distributor’s mechanical advance starts (rpm) and when its vacuum advance starts (mmHg or inHG)?
Wow, great stuff, I completely forgot about Coolerman’s thread. Full of lots of great stuff. He should get a Nobel for it!
I asked about the 2F manual info, because my 1F Engine Repair Manual (dated 1966) has significantly different info wrt the dizzy (it does specify a vacuum advance dizzy). Here’s it’s info:
You can see why I asked about mechanical advance cuz it says that starts at 500-rpm so timing at 650 would have it already in advance. Vacuum advance specs are similar (not sure about the 16-deg max though). Wonder why the mechanical advance specs are so different, published date of the 1F manual fits in the timeframe window of the 19100-61080 (which I have from city racer). Not sure if the manual lists USA (vs. non-USA) spec’d dizzy . Timing at 500-rpm (1F manual) vs. 650-rpm (2F ?) is significant in my book for a lot of factors.
