1973 FJ40 SM465 Swap (1 Viewer)
pbgbottle
Forum Lifer
Cloverdale B.C. Canada
You can mount it off of the transmission I’ve seen guys remove the pto covers and bolt steel plates over the holes and weld there mounts to the plates. U could also remove that rear cross member and use your propeller mount. On mine my adapter had a mount on the botttom. For my linkage it’s just the stock linkage with a threaded hole bored into a piece of flat bar. I drilled one hole deeper into the flat bar to make it sit even on the side of the Tranny and threaded the post is off of the side of my old Toyota 4spd threaded into the flat bar.
pbgbottle
Forum Lifer
That mount you have is a bit fugly I’m not a fan of it bolted to that spot on the tcase but it should work that’s pretty much like mine but instead it bolts to the adapter. And I put my crossbar flat against the bottom of frame rails and ran a long bolt through the frame no bracket welded to bottom frame.
SC
Not sure of your fabrication desire level, but this is what I’m planing to do when I get time- sm465 transmission crossmember mount - https://forum.ih8mud.com/threads/sm465-transmission-crossmember-mount.541541/
Basically, removing to pto covers on the sm465 and creating a cradle in their place. Then creating a crossmember to mount it to. Currently, I’m running a plate adapter and AA crossmember on my Orion. Since I switched to the Orion(cast iron), this project has moved to the back burner tho.
Wow! That looks really good. Probably out of my skill level. What kind of plate adapter do you have? Next time I have to drop the transmission I want to go that route.
SC
Yeah, I have to remove that rear frame crossmember because I can't get the transmission jacked up and level. It's hitting that bar. I thought I would cut it out and move it back but do you think I could just use the propeller in it's place? Would that be okay structurally?
Do you know when AA went to the 5" adapters like you have? I cannot find anything on here or the entire internet about a 7" adapter.
SC
Do you have any pictures how yours looks? My brother came up with an idea for one but we haven't made anything yet.
SC
I was going through pictures on here and see how you have yours set up. Does your AA adapter have bolt holes in it so you could use that isolator on your crossmember? Mine has nothing on it.
SC
Here's what mine looks like from underneath...Nowhere to mount like yours has.
Rocky mtns
So bear in mind I haven’t actually done this, but I don’t think it would be to hard. Like @pbgbottle said make a couple plates to replace the pto covers, weld some “arms” from plate to plate and mount them to a crossmember and attach it to the frame. You’ll need to isolate the vibration and allow some flex, but that shouldn’t be to hard. The write up I found looks really good, but I’m not sure it needs to be that fancy for a wheeler.
i have a concept in my head that’ll incorporate a skid plate as well, but other things keep jumping in line...
pbgbottle
Forum Lifer
Some go without the crossmember but most just modify it or move it back. I’m not sure when they changed the adapter but I’ve had mine for close to 20-25 years. 😳.
SC
Dang! Mine must be an antique!
Do you remember what size bolt goes into the bosses on the side of the SM465? Mines so far back, I can only use that last boss. I’ll have to try to make it as stable as possible. Maybe I can rig up a plate to one of the forward ones. This picture is showing it’s at the very back of the transmission.
pbgbottle
Forum Lifer
Yes mine had the mount molded into the adapter for mounting a crossmember You need longer flat bar to make a mount for your shifter linkage.
SC
Do you have any idea what size bolts fit in the holes on the side of the transmission? I have gone through every one I can find and that tractor supply has in stock. None fit.
SC
Well, sorry for the long thread on here. Maybe it was helpful to someone. I cannot do this swap. The long adapter pushes everything back way too far. The engine is unlevel and I can’t go any higher with the drivetrain. I’m going to disassemble it all and go back to the 3 speed transmission and case that was in it. Thanks for all the tips and info.
