- Thread starter
- #121
So I have the plate adapter now and I am getting the transmission shaft tapped. I took the AA spud shaft out of the TC and there are two gears and some spacers in there when you take it out. Do I just pull the gear that is at the rear of the case out and discard it? That would be the PTO gear I think because it doesn't move any other gears, just spins on it's own. The front of the case gear is what slides onto the SM465 shaft and then you put the big washer and bolt in to hold that on? Then there's a big open space at the back of the TC. Do you take that rear bearing out too? I was wondering that because if there is not a shaft going out the rear of the TC, there's no reason for that to be there. I guess you could leave it if you ever go to a different setup?
