1972 FJ40 Seat Belt mounts
Orange County, CA
I am installing seat belts and I think I am using the wrong locations. I think the rear heater mounts to the locations that I am using. Does anyone have a picture of the locations where the seat belts mount to? Just the middle ones. I have the ones on the door sides.
Does the passenger seat belt go around the middle seat?
Cheers
I am installing seat belts and I think I am using the wrong locations. I think the rear heater mounts to the locations that I am using. Does anyone have a picture of the locations where the seat belts mount to? Just the middle ones. I have the ones on the door sides.View attachment 3830100
Cheers
I've been trying to figure that out too...
[Edit: sorry, the link was bad. Should work now]
Check out this post on my build thread: 1972 FJ40 Seat Belt Anchor Locations
Driver's side is not correct. It would be in the bolt farther forward. Never owned a 72 that had the emissions tank in the passenger's seat back. Believe the anchor on those moved so the seat belt came between the two seat backs. Guessing I have some good pictures of my 70 model I took when I got a stated value insurance. But the passenger side would be different because it when all the way to the end of the seat.
They are two completely different sizes - the pitch is about 20% coarser on the metric bolt.
Just because you can force something into a hole, doesn't mean that it belongs in there.
Let's see (sorry, USA arithmetic)
7/16 - 20 = 20 threads per inch, 7/16 = 0.4375, 0.4375 x 25.4 = 11.1125mm.
11.1125/11 = 1% difference in diameter.
M11 x 1.25 = one thread per 1.25mm
25.4mm per 1 inch
25.4/1.25 = 20.32 threads per inch
20.32/20 = 1.6% difference in thread pitch..
25.4mm per 1 inch
Standard pitch for M11 is 1.5mm, and M11 Fine pitches are 0.75mm and 1.0mm.
While you can find M11 x 1.25, they are like rocking horse droppings by comparison.
I only claimed the 7/16-20 and M11x1.25 were interchangeable.
Note that other OEMs uses the M11 for their seat belt fasteners. I speculate that the NHTSA rule requiring seat belt anchors to use 7/16-20 or 1/2-13 ("or equivalent") permitted the metric M11x1.25 specialty thread for metric OEM's.
Rocking Horse droppings spotted:
Yea they are out there. Just much less common.
Tbf, you'd be hard pressed to find any M11 fastener in a normal hardware shop in any pitch.
M10 and M12 on the other hand are everywhere.
