1970 windshield hinge removal (6 Viewers)
Edwards, CO
Does any one have sage advise on removing rusty screws that hold on the windshield hinges? Both of my pins are broken, and with the top off the windshield flops around like a beached fish. I have removed the paint around the screws with a utility knife, applied bolt breaker fluid (Drummond Open & Shut from Lawson Products) and used an impact screwdriver. I fear my only recourse will be to drill them out and tap new threads. Thoughts? Thanks!
Smoke wrench heat works really well. I watched a guy in Iowa pull the hinges off of three windshield frames in a row. Every single screw came out.
Hint: propane torch isn’t hot enough. Mapp gas or oxy acetylene for the win.
Absolutely agree with 65swb45.
To me drilling and tapping is an absolute last resort. It sounds easy, but in practice drilling through the center of the bolt and maintaining the drill bit's alignment with the bolt is really difficult. It can help to have someone else look from the side to confirm the drill bit is perpendicular to the windshield slope so you are drilling correctly.
Before I went that route, I would try 65swb45's suggestion. If that doesn't work, I'd try welding a nut to the heads of the screws.
Good luck... I don't envy you this task.
Drill a small hole at the rear of the frame behind where the screws enter the frame. Use the tube from the pb blaster and spray the back side of the screws from there. You've got a wire on the right side (from memory) which holds on the wiring for the wiper. One of those screws may be close enough to let you soak the back with pb blaster from that existing hole.
If you fold the screen down you may be able to get enough pb blaster up to those screws from below without drilling a hole. Then make sure you're using a number 3 Phillips.
Hand impact screwdriver should do it. They require a little finesse to work properly if you're not used to using them. I always try both directions to get it broken loose. Making sure the bit is the proper size and I always kind of preload the spring a little by twisting in the direction it's set for to take out slack, then hit it hard with a 2 lb hammer. Heat and penetrant help as mentioned. Only fail I've had was the rear barn door screws on the top that have that floating captive bar retainer in the tub. Ugh. One of those broke off and had to drill/tap. Not fun!
Something to keep in mind with the impact drivers is the bits that typically come with impact drivers are what I'll call "standard Phillips bits". Toyota uses JIS fasteners, and it would be better to use a JIS bit. (JIS = Japanese Industrial Standard)
For your purposes you want as much contact between the bit and the fastener as possible. There is a difference....
I’ve often wondered whether you could find JIS bits for a hand impact. The bits that come with them take enough abuse they need to be replaced. Mine is 45 years old and the bits have seen better days.
The #3 Phillips seems to be a pretty good match, even though the #2 is only so-so. I went through a string of Craftsman #3s back in the day when I was actively dismantling. They had SUCH a good bite that I would sometimes have to put the screws back in to get the bit off!
If you work on your junk and live where they put salt brine on the road, you quickly become an expert on seized fastener removal. As difficult as some 50+ year old fasteners are, you haven't lived life until you have tried to dismantle some rusted junk. Requires more than just hitting it with your 👛. I have been tempted to buy one of those induction heating tools, waiting for prices to come down a bit first!
HEAT!!
I spent a few weeks PBBlasting, Impact Screwdriving... with no luck.
Picked up a $49 induction heater at Harbor Fright and after ONE cycle on each capture nut from behind, each screw came out slowly.
Couldn't heat from the front, but the tool allowed me to bend the coil up BEHIND the dash right on the capture nuts.
Came right out!!!!
I did not want torch flames up behind there with all that old PBblaster, lol.
74 mostly original FJ40
HEAT!!
Came right out!!!!
Nice! I didn't even know HF made an induction heater. I will give it a try for fifty bucks. Thanks! I just looked on the website and don't see it, do you happen to have a link?
can't find receipt nor order history... It's a Hot Rod, bought a couple of years ago. Prices may have changed.🧐
