1970 Steering Wheel Options
USOffRoad
Supporting Vendor
Hico, Texas
Website
www.usoffroad.us
Mine is in pretty bad shape. Big cracks where the spokes meet the hub on all 3. The grip/ring is better, one small crack. This is a 9/69 build.
I'd like a slightly smaller wheel if possible as I'm refrigerator sized. Plan on putting extenders on the driver's seat as is. Not doing a pure restoration.
Not sure what other year wheels would fit or if they are even any smaller but I'll likely need another regardless. I've searched around on MUD but didn't find anything definitive, prefer some sort of OEM wheel.
Do you have power steering? The smaller the wheel without power steering will make non moving turns and parking lots not much fun. I’m using a 80 series wheel in my wife’s fj55 and really like the feel and size
I think I have seen threads about steering wheel swaps - not sure what years they were. Then there is that guy that does the make like restoration of steering wheels.
Mine has big cracks and stuff like yours. My plan is spray them out with brake clean, let dry and fill with black epoxy putty. I'll make leather gussets for spoke and grip ring junction. They will be wet formed and then sewn. I'll wrap the grip ring section with camo or international orange 750 paracord - maybe both.
Here's one of a few threads.
69 would be the different spline count, not the same as later rigs
most likely would need an adaptor of some sort, which would then extend the wheel further towards the driver
7/69 was the split on the steering shaft splines, so his should be 33 spline. OP should still count and make sure.
I like the 80 series wheels (33 spline), which i installed in my non power steering late ‘69 40 :
I recently installed an FJ60 wheel on Lilred (1977 FJ40).It’s about an inch smaller in diameter but still easy to turn and steer with manual steering. Only modification was drilling and installing the two turn signal cancelling pins. Not sure if that type of wheel would work with your year but there are options - and reasonably inexpensive.
In the same boat with a 1970 40 and the steering wheel is knackered.
Would love a bird head resto but also considering a steering column from summit or flaming river that would open up the options.
Even with a column and wheel it is likely lower total cost. Also less total authenticity 😕.
