- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 13,327
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #281
Last bit, it has been discussed to run the t-case off the old dash system. That was a dash pull knob which is a vacuum actuated knob for 4wd. Then use the big dash lever for high/low. That is how it was for 1967. It could be done if the t-case is the 62-series style or we converted the 60-series to the 62 vacuum style. As well as converting the 60-series split case to cable operated. However, it is complicated to do and that means increased cost. A lot of fab and custom work to do this.
At this point, I think we are going floor mount 60-series style t-case shifter. The vacuum knob on the dash will go away but we will retain the big lever. The lever however will run front and rear lockers. Myself, I like this solution. Sure it would be extra cool to have it work like the early 40-series style with the 60/62-series t-case but is it worth the cost and all the fab? Not really and we do still retain the dash lever which is pretty cool to use it to operate the lockers. Don't ya think?
Cheers
Cheers
