What's up ya'll!
This is Judh8smud (or you can just call me Jud) and I'm new to the site and the world of FJ40's.
Here's a shot of my rig that I just picked up from a gentlemen on craigslist. It's a 1966 FJ40. There's clearly a lot of work that needs to be done.
Brief Back Story:
I'm in no way very experienced with automotive restoration. I'm a carpenter by trade. My father and I are working on it together though, and he has a decent amount of experience which helps.
The story on the FJ is that it has had several previous owners and was used on deer leases and what not. The guy I bought it from thinks somebody obviously ran into something like a tree or a rock a few times which explains why the front fender is screwed up. It has mostly original parts all around. It also has a "newer" 2f engine. It's in decent shape to say the least but I will list some of the problems it has.
1. Rust inside and out. (good thing is that it's all surface rust)
2. Not running.
3. Ignition improperly wired
4. Windshield broken
5. Weather stripping deteriorated.
6. Upholstery ruined.
7. Front fender bent.
8. Miscellaneous parts worn out (some electrical wiring, a lot of rubber parts, etc,)
Those are just some of the simple problems that I can think of...I'm sure I'll run into more as I go along
Anyways, we're starting with the engine problems first. As I said, it's currently not running and it hasn't run for about a little over 2 years. Since the ignition wiring is messed up, we've been trying a few things such as attempting to start the engine by jumping it off and other things but to no avail.
What we have done is we have purchased a new battery, its a duralast gold (bottom), recommended battery by our local auto zone for my specific vehicle. We have also replaced the ignition coil with a brand new one. (top left)
This has helped quite a bit so far but we still couldn't seem to get it to crank over. Today we took the starter motor to auto zone and had it tested...it's no good. Thankfully I can have it replaced for around only $60. Once I have that replaced and installed, we're going to try to create a circuit from the distributor to the ignition coil, from the ignition coil to the positive of the battery, and then hook up the regular negative cable to the negative of the battery. Then we'll take the cable that we will attach to the starter motor and tap the positive of the battery to spark a current in hopes of starting the engine or atleast getting it to try. (don't worry, I watched somebody do it on youtube so I know what I'm doing lol)
Other than that, we're going to re wire the ignition and probably most of the electrical and see if we can start it from the ignition after we find out if the engine will start or not.
Here's a pic of the ignition wiring situation...pretty hard to see what's really going on, but we know it's not right, the guy I bought it from said that the previous owner had wired it wrong and fried something. Also, does any one know what the little can is on the right side?
Here are some extra pics just for grins...
Not sure if the instruments work either.
Not sure why these instruments would be necessary but they are there.
And finally a shot of the cab. I've removed the seats and the fuel tank, cleaning that out.
I'm planning on sandblasting off all of the rust from the frame to the chassis as well.
I might do a nice OD green and gunmetal grey detail paint job, we'll see.
So that's about it for now.
What are ya'll's recommendations? I'm open to any questions and advice and I'll be checking in on this thread pretty frequently.
I want to make it a daily driver, what are your recommendations on some vital things that I should do to make sure it's reliable?
Also, any upholstery recommendations?
Thaks guys.
Brief Back Story:
2. Not running.
Thaks guys.
