I'd really like to get a tig so maybe a tank project will spur me into getting one.
Mike
Look forward to seeing what you get (Diversion 180?
As usual - beautiful work.
Mike
Look forward to seeing what you get (Diversion 180?) and what you do with it.
If imitation is the sincerest form of flattery then prepare to be flattered.
I have one x-brace that is a tad rusty and I need a good way to secure the cage to the frame. Your solution is better than what I had in mind. Getting rid of the factory "bench" across the back of the cab sure simplifies the cage anchoring. I am also enlarging the tranny/doghouse cut rearward 7" to allow my Toybox to fit and your setup will help stiffen the floor.
I don't want the tank in the cab so I will likely remove my filler neck and patch the cab corner smooth. On second thought, I'll just weld the holes shut and leave the notch in the cab there.
Are you welding through all those holes in the plate into the floor?
DITTO!
Thanks for the photos and play by play. When I can't work on mine I can at least look at yours.
Thanks Mark. I went through dozens of designs in my head and on paper before deciding on this one. I think it turned out good although not quite finished yet. I still need to add the rear wall bracing.Haven't checked into this thread in a LONG time. Your approach to 'solving' the rollbar issue may become the 'standard' for 45 owners, making you the PIONEER!
VeryMike.
On the trans tunnel cover, since you have to build/modify, I urge you to consider inverting the forward section on the driver's side, getting the vertical drop to start more or less alongside the transmission. This should yield 3 or 4" of foot space in that overly crowded area between the gas pedal and the hump.
I WILL make that mod to my 45 one of these days.![]()
