- Thread starter
- #41
I think I'm going to unsubscribe from my own thread lol
I don't think that it has a delta wound stator because of the use of 4 diode pairs. In a wye wound alternator, you can also rectify the current at the common connection of the 3 phases producing a little more power at low RPMs. Most alternators since the late 80s take advantage of this.
some alternators use the current at the common pole to run the idiot light charging indicator.
The other reason I think that they use the stock wye configuration is that there is an over riding desire to produce more voltage at idle RPM so that the lights don't dim and the battery discharges at idle.
I rewired a Ford large case alternator into a delta configuration for use as a welder, but I did not notice any difference in its welding ability compared to the wye. You still needed to rev it up over 3,000 RPM to run a decent bead either way.
I think My brain just exploded.
what is the meaning of life?.....
Are we having fun yet?
which alternator should one purchase in order to get the 160 or 180 amp output?
So the dimensions are;
160amp
Diameter: 17 7/8"
Rectifier 'B' terminal size: 1/4"
180amp
Diameter: 19 1/4""
Rectifier 'B' terminal size: 3/8"
I sure hope you meant circumference, otherwise i'm never gonna get this thing to fit under my hood.And now that I've gotten to kick you in the balls I would like to say thank you for being such a good sport and posting your finds to this thread. I know that many of us are eager to see what you come up with and its nice to have somebody else pioneer new stuff.
