Before you drop the coin on the big Grp 31 Odyssey, realize it takes a weird charge profile to live a normal life. How many of our alternators will charge at 40 amps up to 14.8 volts? None. It will basically force you to buy an expensive charger and plug your truck in every night. To me, it makes far more sense to just buy a decent conventional battery. No strange charging profile, no special needs, you can add water if you need to, and for the price of 1 AGM battery you can buy 3 conventional batteries.
Interstate is now made by Johnson Controls. Interstate does not make batteries. They market batteries. I don't know if that is good or bad, but the exact same batteries are available at Costco.
I think it is best to look at batteries as a consumable item, and just 1 more thing to replace at a scheduled interval. Conventional batteries with a bit of care go 4-5 years. AGM batteries go 4-5 years too. If you have special mounting needs, like placing it on it's side, by all means get an AGM battery. But if you don't, you're just paying more and not getting more.
We had some of this same discussion in the Sequoia alternator thread, but if you don't have a need to generate 150 amps, why would you bother? Batteries can only accept charge so fast. So a bigger alternator will not recharge them faster. Plus, their last 10% of charge is accepted VERY slowly-just a few amps, so no matter how much alternator you have, it will not matter. The only reason you might need a bigger alternator is if you have a large continuous need-like giant lights, life support equipment, or huge powerful radios. That's why ambulances have upgraded alternators.
The 80 has a 90 amp alternator stock. Someone added up and measured the worst case scenario in an 80 and came up with 57 amps continuous. And that's literally every electrical item turned on high. So you can see why a 90 amp alternator is actually plenty, and even has a 40% reserve capacity already.
Regarding Dave 2000's comment-He is confusing amps with power. Assuming starting your engine uses 150 amps for 5 seconds. That's actually 0.21 amp-hours. Your average car battery has about a 75 amphour capacity. So to replace the cranking power back to the battery is nearly instantaneous. Even if you have a charging current of just 1 amp, all the power would be replaced in 12 minutes, at 10 amps(more realistic), just over 1 minute. The point is, the power to start your car is trivial interms of the capacity of the battery. It takes a high current though, but for just a few seconds.
