Hi all
After cooking my clutch in my 1985 12 volt bj70 on the weekend I have decided to swap in a 24 volt 13 bt sometime in the next week to replace the tired 3b. The 13 bt is a 1989 blue block (8 bolt flywheel) I have read that it is different to the original 3b 6 bolt flywheel. Are the body mounts the same ? Is it a in and out or is some modification needed ? I would also like to keep the truck 12 volts so any info on converting the engine to 12 volts welcome. Are the electronics the same on the post 1988 13bt's the same ?
-cheers in advance
-cheers in advance
