13-15 LC LED fog lamp install (1 Viewer)
bloc
Central Texas
Hello all,
Us 13-15 landcruiser people don't have any really good bolt-in LED fog lamp options due to toyota using a larger pattern for their mounting brackets. The same year LX has a compact assembly that is shared with other more common toyotas and as a result the LED manufacturers offer some nice drop-in lights that can help a lot at the function of actual fog lamps.. that is, low-glare light color, illuminating the road under the fog.
This past summer I pulled my old fogs to take some measurements and see what I could shoehorn in there even if I needed to build some adapters to make this work. @CharlieS had done this in the past, having a shop bend up some brackets that worked great, but were a bit pricey on top of the lights themselves. Diode Dynamics was doing a Labor Day (i think) sale and I snagged some Elite Type B lights, and those have been sitting around until I could find time to make this all work. I have a ski trip coming up next month and needed to get this sorted before all of the snow driving so a few days leading up to christmas were dedicated to this.
A note about fitment.. I'm not sure if this will work with other brands, but the DD type B format has the offset front lens like our stock ones, and the ears aren't a direct fit but close enough to (relatively) easily make adapters.
It is possible to do this job with the bumper skin staying in place, just remove the lower plastic gap cover and loosen the fender liner, then you'll have enough room to loosen the stock fog lamp and bracket, then two more bolts to get the surround out of the bumper. The hardest part here is loosening the clips that hold the wiring harness in place.. not a lot of room to work. Once the two parts are separated they can slip out the gap at the bottom and you'll have this on the work bench.
This is the whole gray and chrome surround with the lamp and bracket slid into place. There are two ears on the left that fit into slots, and two 10mm screws on the right that hold it in place.. I have these removed.
The goal is to get this to fit the same way
First I traced the old bracket and rough position of new mounting ears.
Cut out some unneeded meat.
A fair amount of fine tuning to get the bracket to fit snug.
Dig into the old bolt bucket and mock things up. This is the second revision where I used a different strategy to get the extra aluminum cut out.
Second and first draft, respectively. I did end up rounding some edges before copying to the other side and final install.
After sorting out some unrelated bumper harness issues and adding a bit of plasti-dip.
Note that I haven't yet aimed them for correct beam angle.
I'm really happy with the results, especially considering how simple they were to build. I don't really think there's enough of a market from this specific year range/model to justify selling as a product so I'll probably just clean up the dimensions and post them for others to copy for personal (not commercial) use.
So stay tuned if you'd like to do something like this.
Could they be 3D printed, plastic? Or do they need to be stronger.
My son has a spiffy new printer, makes amazing things with it.
I don’t see why not with a rigid enough material. We could actually improve things a little.. the 1/8” material is slightly thinner than the ears of the stock bracket allowing just a little fore/aft play.
I have a friend with a scanner that I can probably ask for some help.. let me get through the holidays and see what can be done.
Hey! Did this ever go anywhere? I have a '15 and am interested in getting some aftermarket fogs... Thank you!
We couldn’t get a good scan of the aluminum parts with the hardware we had available. Pretty sure I still have the notes at home with dimensions that should be usable.. but won’t be home til tomorrow. I’ll check then.
That's very neat! If you have the dimension, that would be awesome. I can attempt to draft it up in Fusion 360 and do some prints with PC Blend.
I had the DD SS3 Yellow fogs in the Pro(F150) and Max(GX460) models and they were both fantastic.
Nicely done, which lights are you using? Any wiring issues?
I've physically confirmed fitment with diode dynamics ss3 tybe b and morimoto 4banger type s. As long as it's for the vehicles listed in the link, they will work great. The reason I designed it around those fitment of pods is because it allows the end user to choose more or less any brand, and they will have the same end result in terms of fitment. The ss3 and 4banger are designed around using factory wiring/input, no relays needed. I've run both brands on multiple vehicles with not a single issue!
