12v ignition power for electric fuel pump?
Williams lake b.c canada
Have a 75 fj40 with a Chevy 350 have to run a electric fuel pump because it is a tbi engine.looking where I can easily get 12v ignition power for the relay/pump pictures would really be appreciated thanks.
You can trigger the relay from the idle cut solenoid wire or voltage regulator. The coil is on the passenger side of the harness, so it is probably closest.
And mount the pump by the tank, not the engine, electric fuel pumps are pushers, not suckers.
What would you use to mount an electric pump IN the tank?? Investigating doing this mod to my already modded to the hilt 40...
Cheers!
Maybe look at ebay #263646816962, can be shortened for factory tank.
