Our drive-ability test of sorts was the partial throttle, loaded dyno roller test. That was the best method we (and the professional tuning shop) could determine to test closed loop performance and provide objective (numerical) results.
We've got 30,000 rows of datalogs and professional analytics software we can comb to search for any subtle differences in engine response. I wasn't able to find them, but I'm happy to run some analytics on any hypothesis you can suggest.
The following was plotted for difference in the two populations:
- Fuel flow rate per power
- Fuel flow rate per torque
- Ignition timing
- o2 sensor variance between commanded and measured AFR
I haven't been shy regarding my skepticism on this topic. That doesn't preclude me from maintaining scientific integrity during the test or drafting its results summary. Myself and 3 others had varying hypothesis on this topic and were interested in objective results and an unbiased scientific method.
As the thumbnail indicates if you've got a counter data set, by all means, "whip out your data." We're interested in the truth here, not proving anyone's preconceived opinion.
The point of 12 hole injectors is, and has always been, for better on road driveability.
None of your testing included that since your test vehicle was strapped down to a dyno and was stationary. Also, our trucks have an adaptive memory ecu. If your before and after test was back to back without giving the ecu time to adapt to the new mod, it was inconclusive.
However, none of your data surprises me and I’ve installed several sets of 12hole injectors on several trucks. I’ve also road tested said trucks with great detail. After road testing, my conclusion was that there was no power gains from simply installing 12 hole injectors. However, the driveability was much better and that they are well worth the small investment.
I also have feedback from literally hundreds of 2uz owners running 12 hole injectors. Better driveability isn’t an opinion. It’s either better or it’s not. You’ll never see somebody with 12 hole injectors say ‘dang, these suck, I’m putting my 4 hole injectors back on”. At least I haven’t ever heard anything like this after talking with literally hundreds of owners of 12 hole injectors.
In other words your testing may prove something that I’ve told people to be true since I first discovered the option to install 12 hole injectors back a couple of years ago, there is likely no power gains.
What is unfortunate is that your testing is incomplete and people will see it and think that it conclusively rules out this great mod as being worth it. While there is no ‘data’ showing more power. The fact that your truck downshifts less, stays in a higher gear more of the time, has better driveability, is more responsive, and just overall picks up the way the truck drives, makes them a very worthwhile mod.
The differences noted above are subtle, but if you’re a ‘driver’ you will notice them.
BTW, I agree with your research regarding air filters. I doubt they lose power, if you had given the ecu time to adapt rather than doing back to back tests on a dyno you’d have found that either filter made the same power. The benefit of a washable air filter is that you never ever have to buy another air filter. If you’ll notice, I have been posting on tundra forums since 2003. Never once have I said that an air filter or cold air intake makes power or is worth buying (cold air intake). Matter of fact I don’t post air filters or cold air intakes on my site. But I absolutely recommend
12 hole fuel injectors for your Land Cruiser or Tundra with 2uzfe
