06/07 Air Induction Pump Failure & Bypass (1 Viewer)
Ok, Thank you for all of your feedback. I will update what I end up doing. I understand this is a violation of the Clean Air Act so the bypass is illegal. However, I am curious if you would pass an inspection with a bypass installed?
I just registered mine here in Nevada and we just have to do SMOG and mine passed. I just got my tags yesterday for 2025. I guess it depends on the state/city if they will scrutinize your vehicle down to the components installed and identify if its legal/illegal.
"curious" What difference does it make. Either you do all you can to keep your combust engine as low a pollution emitter designed. Or you don't!
If one can break the law, without being cough or fear of penalty. Should they?
Installed the full playground and play Gen 2 kit and the corresponding codes went away, but it immediately threw a P0136 (o2 sensor) code. I replaced that sensor but the code is still showing… are there any overlapping issues that may cause a o2 sensor code?
Oops
The Gen2 kit should have nothing to do with an O2 Sensor code. If this was a Gen2-3V kit where you have to wire the 3 wire whip of the harness directly into the ECM, you may have damaged another wire or possible wired into the wrong wires. Please contact us directly with pictures of your installation. If this was a Gen2-3V installation we particularly want to see the bare wire connections at the ECM where we can very clearly see each wire, the factory wire and the terminal of the connector it goes to.
