02-07 Stereo Headunit Tesla style
I’m in for $50. Just send me your PayPal. Would like to understand what thexwiring harness differences for an ‘04 LC are though. Seems like they reuse the AC amp and some of the other nvac control boards.
Just leaving this here. Not sure if they mean we just need to get the correct trim pieces or the HVAC controls use different connectors. According to the photo its not compatible with the LX470. Not sure of LCs. I sent them a message via whatsapp to see if I can get a reason behind it
I'm thinking you are correct.. I purchased the gray Land Cruiser trim piece to do the Nav Delete but was able to find the correct panel so I sold them.
This might work 55660-60170 and 55670-60110 from Megazip. It is not the exact match for the LX ...it's darker and called Sandalwood ... i think it might be plastic
Thanks Lou. I sent that photo as well informing if thats all we need to buy to make it work. He stated he will double check on the wiring and let me know if its possible. Again, per the details of what they are selling the following consoles would not be compatible as of now:
Great news LX470 users, as long as we get the panel above mentioned by Lou installed, we can use this product for US spec LX470 '03 and up. For '03 and up LC100 users, you just need the nav unit after sending them a picture of what you have currently.
Purchases will be processed after Feb 13th (holiday overseas) and they can set the temp to F if requested. For LX470 guys we just need to be sure that we specify our current console and that we would be purchasing those vent panels to get the correct wire harness.
So total of $485 32GB or $515 for the 64GB shipped
Will I be the guinea pig? Maybe at the end of March after my travels to South America. We shall see. ;)
I wonder if this will drive the Mark Levinson system. I'd definitely be interested in this if I can get it to work.
Great news, as long as we get the panel above mentioned by Lou installed, we can use this product for US spec LC100 and LX470. '03 and up.
Purchases will be processed after Feb 13th (holiday overseas) and they can set the temp to F if requested. We just need to be sure that we specify our current console and that we would be purchasing those vent panels to get the correct wire harness.
Will I be the guinea pig? Maybe at the end of Feb. We shall see ;)
Sargy...it your friendly neighborhood White Rhino driver...let me know if you do this...I can lend a hand if needed, or just watch...will pitch in too if you do this.
Will it work on the mark Levinson system for an 04 with the LC panels?
I’ll temper my enthusiasm and resist sending any money to a four post user that joined three days ago and has only posted in this thread.
Of course if you’re legit you’d understand, and if you’re not, well, you won’t.
The unit does look interesting.
According to them, yes. Just need to make them aware of which nav/console combination you currently have.
Will do, neighbor! Once I return from South America in March I start looking into buying a unit. After seeing many videos from this youtube channel on other cars / trucks, im starting to get convinced that there is a good following on this. It appears to be using the same type of UI
Phoenix Android Radios
Eagerly awaiting your install report! Hopefully the wiring harness is pug and play and all the air con functions work as described. Good luck!
Also would be great to know if the radio portion of the unit has RCA preamps or just speaker level outputs. I nuked my factory amp a few weeks ago but kept the head unit so that all of the other ECU stuff would work.
My concern with these chinese products is that they usually pick up the cheapest components. I had experience with double din units that failed within months. I wouldn’t mind paying more to ensure quality in line with the rest of the car.
