semlin
curmudgeon
some true 80 series tech here...
not sure if this is a 93-94 only issue or if maybe my truck was missing a part.
I took apart my ds power window switch assembly to expose all the contacts and cleaned all the carbon off the contacts with isopropyl alcohol and q tips. it made a dramatic difference and i highly recommend it.
BUT, if you do this, watch out for the tiny spring inside the window switch lock button. when you separate the plastic switches from the circuit board and contacts, the window lock button can come apart. it consists of two plastic pieces and two springs. one of them is a tiny spring on one side that makes the switch alternate between up and down when you press it. nothing is holding this spring in place so be very careful not to play with that switch while the assembly is apart. It was super finicky to reattach the spring and have it hold when reassembling the switch. I have no idea how toyota does it at the factory.
incidentally, i discovered that the up contact on my driver side switch is physically worn away about 50% at an angle. I assume the carbon was so bad that there was minimal contact and it was arcing. For now it works fine but there is less surface contact than designed so I expect it will carbon up quicker to have to replace the whole switch in the not too distant future since there does not seem any way to just replace this piece. if your up switch is not working well consider cleaning these contacts sooner rather than later.
