Okay I'm no master mechanic and I have a ton more to learn about Cruisers so please bear with me here.
I have a '76 FJ55 with 2F that is having some engine issues. The engine idles just fine and runs well at low RPMs. But when I get into 3rd and 4th gears driving down the road, the engine will start to stumble and eventually backfire. While it is stumbling it's like the engine isn't even running. Almost as if I let off the gas so that it is coasting and engine braking, but it isn’t firing. If I push in the clutch and give it some gas the engine will rev back to life like nothing happened. But the second I let the clutch out to maintain speed it will stumble and backfire again. Because of this I cannot get above 45-50 MPH.
The odd thing I have noticed about this is it only happens when it is warmer than say 60 degrees out. At 4:30 in the stinking morning when it is cool out I have no issues with the engine. It runs fine. And I didn't have any problems all winter. It just started doing it this last month when it started warming up.
Its seemed that as this past month has gone on and the days get warmer it starts doing this at a lower and lower RPM.
So I was wondering what could be causing this stumble then backfire? Do the valves need adjusting? Or could it be my dizzy? What could the problem be? This is my DD so could really use some info ASAP!
Thanks guys,
Thanks guys,
