Well since the web page is bugging me about not posting in several weeks I thought I'd share a couple of pictures of my slow progress.
I've just finished installing the 12si 94amp alternator on the stock bracket. I machined the bracket's inside ears to locate the alternator in the correct position to line up with the stock tension arm. I run the belt on the inner pulley set using a new smaller pulley for the alternator. With the smaller pulley I'm running around 3x crank speed, so I've got good output at idle! You can see in the lower left of the pic that I added a sliding sleeve like the original mount, but it now biases the alternator to the front when the pivot bolt is snugged down. I still need to get a shorter pivot bolt, but the rest of the install is complete. The wiring is pretty straight forward for a 3 wire install. The output is tied to the battery direct, the voltage sense is tied at the battery too, and the excite wire is connected to the ignition switch via the old alternator harness. I did insert a diode in the exciter wiring to insure that the engine won't run on when the key is turned off. I also doubled the capacity of the wire running to the fuse panel, and removed the ammeter. The headlights have been rewired with relays to remove that load from the original wiring harness. (that mod is worth 1 - 1.5volts more at the headlights)
The last couple of pics show my new booster and master cylinder install. I'm working on the new hardline routing now, with only a couple more pieces to form. It was hard to find a clean routing for the residual valve and adjustable proportioning valve. I hope the routing I've done won't have any problems with vibrations.
At least I've been able to make double flares without any problems. Since there aren't any NPT to Metric double flare adapters that I can find, I just had to put english flare nuts on one end, and metric on the other. You would think Wilwood or someone would offer metric adapters for their products.
That's my progress for the last few months. By the next time I get the reminder to post something maybe my brakes will be done!
Jeff
Jeff
