Hello diesel crowd,
As the title suggests, I'm in search of guidance for adding a turbo to a Toyota 3L engine, mechanically injected and naturally aspirated. Specifically, a good friend of mine recently purchased a 1997 Dyna 150 with a 3L from a fellow who had imported it directly from Japan. Right hand drive cabover model. I helped them do the timing belt/ water pump/ tensioners and serpentine belts back in January. The exhaust manifold was leaking soot under the cab and into the vehicle, so we replaced the exhaust manifold gasket and used a stud kit instead of bolts. After a 1900 mile road trip, everything was fine but within the last 50 miles it started leaking exhaust from the manifold again. So at the very least the exhaust manifold is warped and needs replacing. Given how the vehicle has only 60,000 kilometers on it I doubt the head is warped.
Given how the truck is really underpowered going up hills, and the exhaust manifold needs replacing, I'm thinking this is a good time to convert to a turbo setup. The goal is simply for better economy and a better breathing engine. Being a camper it's not winning any races and with mechanical injection it's dumping more fuel than is being burned when under load. The transmission is an automatic so that takes away the ability to downshift ahead of time for big climbs. Overheating has not been an issue so far, and if possible I'd really like to have an air to air intercooler plumbed in somehow as well to keep intake temps in check.
So with all that being said, what turbo would be ideal for modest power and general overall economy? What is the maximum safe boost for this engine on stock head bolts when adding a turbo? I know nothing about Toyota diesels, my main experience is with VW TDI cars and GM 6.5 diesels. So I'm no stranger to the general principles of how diesels work. I've seen the CT20 turbo mentioned often as an upgrade. Would this be a good fit for the 3L engine and my desired application? I'd prefer a turbo that is only oil cooled. It seems some CT20s were both water and oil cooled, some just oil. With space under the cab being limited I'd like to avoid additional coolant plumbing if possible. And an external wastegate that can be manually controlled would be great for dialing in maximum boost. If there's another turbo from a different vehicle/ manufacturer that would be similar or better, I'm all ears.
@GTSSportCoupe I see you've got extensive experience with the 2L engine and making power, anything to suggest?
