What Did You Do with Your 80 This Weekend? (134 Viewers)
Looks great- about 80% of my cluster lights are out lol. Assuming you got new bulbs, did you go OEM or are those LED?
Thanks! They are Led these are for the backlights the gear indicator bulbs are different
Cleaned sugar out of my gas tank :mad:. Must have happened to previous owner. My 97 Fzj has been pinging since I rebuilt it and I was going to swap fuel pumps between my 97 and my 96 to see if a weak pump was causing the pinging. I found a new pump in the 97 cruiser (appears to be an oem pump) which I thought was cool until I noticed the sugar around the fuel sock and at the bottom of the tank. Luckily it appears to all have been collected in the baffled section where the pickup is. I drained the tank then vacuumed and wiped out the sugar. Really hoping my entire fuel system isn’t contaminated, as I already put in a new fuel filter and injectors while rebuilding the engine last year. Didn’t end up putting my 96 pump in it for fear of possibly damaging it.
View attachment 3223852View attachment 3223853View attachment 3223854View attachment 3223856
How the F did sugar get in there? Someone sabotaging? 😳☠️
I haven’t touched it in a month. Had to fix that.
