shtbrwn86
Had a neighbor make me some brackets to mount some fog lights to the frame so I wouldn't need to cut anything or drill any holes. I think I need bigger lights! And yes I am painting them. This was just to test the fit.
How do you like them? I've been considering them for a while myself.
Like the mic connector in the console- nice touch.
Don't worry abt it too much, the valve cover has internal baffle, so the grommet won't find its way into the engine. Put the new grommet in and enjoy!View attachment 3220352
Was going to change pcv and some hoses today. But half the grommet fell into to the hole and it’s not recoverable . Really don’t want to pull the valve cover gasket off as I just did them about 5k miles ago
I wouldn’t worry about it. Same thing happened to me. There’s a shelf thing in there that keeps it from falling into the engineView attachment 3220352
80mm noctua pc fan could help alleviate the heating issue and they’re known to be one of the quietest fans on the marketLike the mic connector in the console- nice touch.
Fwiw- I’ve got my MXT 275 in the same place- and it gets HOT if your using the radio a lot- keep an eye on it- position the heat sink so there’s air flow around it-
Uh oh. You got a picture of the bolts?Spend whole day Saturday to change the timing belt by myself. and new Radiator
After all the assembly, I have three extra bolts
But the car runs and drives fine, I will just pretend those three extra bolts are not from my cruiser.
I had considered a pc fan mounted in the back of the armrest console where the rear audio controls are. Thanks for the size and make suggestion. Would you recommend mounting on the MXT or as an exhaust fan?80mm noctua pc fan could help alleviate the heating issue and they’re known to be one of the quietest fans on the market
I'd do it as an exhaust fan and see how it goesI had considered a pc fan mounted in the back of the armrest console where the rear audio controls are. Thanks for the size and make suggestion. Would you recommend mounting on the MXT or as an exhaust fan?
Last trip to CO I had been on the radio all day and noticed the left side of the arm rest console was abnormally hot- very hot- due to the MXT-
I hit eject on the radio and this came out!
what wheels are on you running? looks good.I used it for it’s intended purpose. It was… a weekend at Windrock. I managed to finish trail 22 right before conditions got really slick, and then got stuck after going back and trying to help winch my buddies behind (one of them with bad brakes and a non-op winch) out. On trail all night. But we all finally got out and learned some stuff. Recovery practice, I guess?
The last pic is because the truck did what I want it to always do- drive home after putting up with my crap. And make my wife’s GX look extra pretty.
