Official ONSC member buying/selling thread (32 Viewers)
Anyone need any of the stuff in this photo before it heads to the trash? This is all the stuff I have left over from my recent work.
The alternator will need a rebuild.
The water pump seemed to be working fine, just decided to replace it while I was in there.
The mounting points of the fan shroud are broken off but it’s good condition other then that.
The fan blade has some surface rust on the ring so I decided to replace it. Worked fine though.
The exhaust manifolds did not leak but did have some welding done on one of the bolts going to the y pipe
The harmonic balancer has some wear from the bearing but could be cleaned up.
*Not in the photo is a stock fan clutch, replaced when I upgraded to a modded blue hub.
I bought 8 containers in a auction by mistake. I am keeping two and holding two for someone until next week. $120 each. I dont have dimensions or specs. But can get it. Shipping on your dime and we can arrange mudship from clt. I look them upand they are around $250 each.
Interested in dimensions / brand and I can look them up. I may take 1-2 of them.
Dimensions, by now most of them are spoken for. Some people waiting on dimensions. I can bid on more but this was a wrong click.
Two jonny
Two andy
One eric
One john.
if one doesn’t go through i let everyone know.
I've had this for a long, long while and obviously will never install it; complete 100 series OEM sub-tank kit; with 100 series dual filler neck, tank straps, transfer pump/solenoid with bracket, George Scolaro's transfer ECU, 2 105 series "SUB" switches. $1,000
Partial FZJ80 engine wiring harness. Minus the IAC and TPS plugs. I used those to make a jumper harness. There are 4 new fuel injector plugs on here but there are some cracks in the wiring insulation and the remaining plugs are original.
$50
I have more coming at a higher price if anybody interested. Also have smaller ones but have to see what price
I've had this for a long, long while and obviously will never install it; complete 100 series OEM sub-tank kit; with 100 series dual filler neck, tank straps, transfer pump/solenoid with becket, George Scolaro's transfer ECU, 2 105 series "SUB" switches. $1,000
This is totally one of those things I really want but in absolutely no way need...
Post it in the CLCC and Keystone forums. I’ll transport it to Nova next month If someone there wants it.
