Purchased the dizzy cityracer sells and am attempting to install it today. It’s part number 19110-61180 (mid cap?) and will replace the HEI the PO put in. Am I correct in assuming that I will also require a distributor clamp as well?
I don’t have the luxury of having a stock 60 dizzy and have this gone with what I can find. It’s going back into my 1984 2f fj60. I’ve tried to locate a stock dizzy with a functional vacuum advance but have had little luck
He won't do it if it has a bad vacuum advance.Used '81-'87 dizzy, send it to JimC...$150 & your golden.
Don't send him one with a bad VA...there're out there. The OP should keep looking.He won't do it if it has a bad vacuum advance.
@Rube Here...
Doesn't anything about being broken, but if you don't I will. (don't need one at the moment)
FJ60 TOYOTA LAND CRUISER 2F ENG. 1980-1987 DISTRIBUTOR OEM | eBay
I wouldnt consider that blowing money. Talk with City Racer and see if you can return his since you were able to find a true FJ60 large cap.Here’s to blowing even more cash. thanks for the lead!
