- Thread starter
- #81
Got 2 of the pipes welded up. Using several flanges to make it easy to take apart and repair the drivetrain.
do you know part # for that muffler , i did se one like that on salvage yard in tahoe but i can't find it in store all i can find is two pipe exit one enterExhaust has been time consuming. I'm using lots of flanges so I can remove sections easily. Muffler is ready to go. View attachment 1642737
Its in the neighborhood of 11.5W"x21Lx7"tall. I had to use a big soft mallet to dent in the side nearest the lower frame side control arm bracket since the bracket protrudes out but not too much. I don't have a part number, its the muffler used in 4x4 tundras for the last 3 or 4 years with the 5.7 3ur motor. My 80 now sounds pretty much exactly like a new tundra. It really has refined the overall feel of the rig, just sounds quiet and smooth compared to red-neck chevy like the po installed muffler. I think you could find one at a salvage yard with a newer tundra. Would just take some safety glasses, a sawzall, and 10 minutes to remove.do you know part # for that muffler , i did se one like that on salvage yard in tahoe but i can't find it in store all i can find is two pipe exit one enter
and do you know dimensions of it ?
2.5" in 3" outthanks i se now it is toyota i was looking at gm muffler ,gm has one similar to that one but but 9" wide and has 2 inlet and one exhaust port
what size did you go in and what out ?
Are the ones sold on fleabay not correct? There are a couple listers there with glass
Euro clear depo lights for 90-97 but I'm not sure if they're direct fit for the 91-94 cruisers.
Finally got a chance to work on the 80 while I wait on parts for my 40. All the gauges are now working. I swapped the tach for a 93 tack. I also installed the bottom indicator from the 93 that has the locking differential lights and installed wires for the locker lights. Now to start putting the dash together. The 92 has openings on the back for the locker light, just traded the circuit board to see with pins to add. View attachment 1695842 View attachment 1695843
