What have you done to your 100 Series this week? (58 Viewers)
Got my auxiliary lights installed. Will post up more info in my build thread
Got it custom made. Will take better snaps tomo.
Please do because I’ve been interested in doing the same thing for a while
Replaced rear OME shocks w/ Ironman Foam Cells, rear sway-bar bushings, all four rear caliper cylinder slide pins, and did a correct bleed of the rear brakes.
He stops and rides like new again.
Oh, and cruised past 277,000 on the clock...
Finally got the parts to finish up the heater t's! Now waiting on my door actuator, will I ever get this thing back on the road!
Did alot of things in the past 5 months on the Lc. Overhauling the engine & automatic transmission. Just finished the first 1K kms on the new setup. Tinted all the windows using Solar Guard does look cool!!!. Got a new set of Method Race Wheel Nv and painted in Verde Artemis wrapped them Radar Renegade A/T 5 285/70R17 Tires. Changed the audio using ground zero speakers, amps , sub , tweeters and Pioneer Headunit. Got the interior detailed and took it straight to the dunes.
what are the specs on those wheels. thanks.
I put my 33's on Method wheels, oh they look so good. They stick out about 3/4" pass the fender, this is 1/2" more than my OEM wheels + 30mm spacers.
I honestly think 33's are perfect for our trucks. yeah?
what are your wheel specs before the 30mm spacer
The pic of the Method Wheels are without spacers, they are ET +25 offset, OEM were ET +60 offset.
My previous setup was OEM Tundra wheels with 30mm spacers.
Thanks for the info! Do you have a land cruiser or LX470 im not sure if the wheel specs are different as a result.
I have an LC, but both vehicles have exactly the same specs.
Here's OEM Tundra wheels with 30mm spacers
Here's a similar angle with Method wheels, +25 offset and NO spacers
The method stick out a little more since it's 5mm more aggressive and 1" wider
Thanks so much. Where did you buy your method wheels i want to buy some.
