ToyotaDon
I am here
This is actually kind of embarrassing.
When I bought my '94 FZJ80, I saw the locker switch, and checked for the actuators, and even tried actuating them. I got the rear to lock without too much trouble, but the other light just kept flashing. I figured the actuator was just seized, so I've put off addressing it until I get to the knuckle rebuild.
Well, this week was slow at work, so with permission, I pulled the rig into the shop and started fixing oil leaks (valve cover, oil pump, P/S pump). While in the air, I took a closer look at the front diff lock actuator and found nothing connected to it!
The brackets mounted to the sway bar are supposed to have something attached to them, namely, the locker harness. I don't know how I didn't notice this before.
I think I saw the pigtail harness coming off the actuator and assumed that was all there was. NOT!
You can see in this next pic where the indicator switch connector is broken off, and the actuator connector is even broken.
Not sure why it's missing, unless someone cannibalized this truck to fix or modify another. The broken pieces point to some kind of violence, either an accident or theft.
I ordered a harness to try and get this working. Got the only one they had at the San Ramon parts depot.
