Waggoner5
SILVER Star
I think this is a good time to start publicly documenting specs on all of our trucks regarding the amount of lift, caster correction, and which type of driveshaft we are running, also documenting if we have DS vibrations, and exact alignment specs if they are available. I don't want this to be conversation thread, only a spec thread, so all of us old and new, will know what works in general. Please list your lift size, what type of caster correction you have and if you are using front, rear or both stock or CV type driveshafts. If you have alignment specs for after your truck, please list them. Also, if its possible get fender measurements so we can have loaded heights. This can later be compiled to spreadsheet for reference.
1996 FZJ45 Loaded height doesn't count
7.25 inches of lift, all Slee stuff, front arms, rear uppers, CVs front and rear, very slight vibs in front only at high speeds. Caster is 2.75L 3.0R
1997 FZJ80 Sold truck so I don't have loaded height, but it did go up 3 in front and 2 in back almost exactly.
3" front springs, 2 " rear springs, Slee caster correction brackets, stock shafts, no vibs at any speeds. Caster 3L 3.7R. Truck has slight pull to right because of R lead in caster. Could be corrected with bushing on right side.
