- Joined
- Jul 2, 2003
- Threads
- 132
- Messages
- 950
- Location
- Glen Waverley, Victoria, Australia
- Website
- jonathan-ferguson.au
Whilst my Car is sitting in the driveway doing nothing because the Engine is out off being rebuilt for the second time, I decided to changeout the gearoil. Having put the rear of the Car on stands I shook the tyres to check that the Car was steady. - I thought maybe the Wheelnuts were loose, so I got out the Torquewrench and set it to 90 ft/lbs. and got only an itty bit of movement out of 'em. After all this and looking at the four axle nuts, it appears that the rear wheelbearings are flogged out at 200,000 miles to the metre.
I know how to pull the Axle out in it's entirety, as I removed the third member back in the day to put a Lock Right in it.
I've looked in the Gregory Manual for the Hilux and the Toyota FSM for the BJ40 under the Semi Floater section, but it doesn't cover Wheelbearing replacement in enough detail.
What I want to know is if it's necessary to remove the Drum to facilitate the removal and replacement of the bearings and seals?
Any pointers you chaps would like to share?
Contrary to the norm, my Pickup Truck wasn't leaking oil.
