I just did a nv4500 swap into my 79 2f powered 40. As a result of this new swap my rear drive shaft is angled incorrectly do to the transmission being lower than the rear axle
. The options that I have come across that should fix this problem are
1) cut into the fire wall and lift the engine higher, allowing the drive train to start at a higher angle...I would rather not cut my tub.
2)Add a 4" lift kit, lowing the rear axle with respect to the transmission.
3)Add shackle extenders...not sure if this would work. If this does work, I definitely am leaning towards this as the simplest and cheapest options.
I currently have a 2.5" super lift with one leaf removed from the front and rear. I'm planning on reinstalling the rear leaf that was previously removed. Also, options 2 and 3 will allow me to get the 33x12.5 tires that I am planning on getting
I've attached a picture of the drive shaft and a picture of my current shackles. As you can see for the drive shaft pic, I only need about 2" to level out the drive shaft. All advise and suggestions are greatly appreciated.
