Anyone running this radiator for SBC in your 40
Normandy Park Wa. ........now in San Diego Ca.
Core Dimensions: 17 1/8" high x 19 1/2" wide (3 row core)
Overall Dimensions: OEM size
Upper inlet: 1 1/2" located on driver side.
Lower outlet: 1 1/2" located on passenger side.
Auto trans cooler: included
Bracket mount system
OEM style brass petcock drain.
Billet style fill neck construction NOT STAMPED
Radiator cap is included
Looks like a good one for the price (Under 200.00 +)
yes...
...but I need to redo my shroud (an original) to better fit the lower, tilted up, rearward 283SBC. As is runs at 180-190 (180 thermostat), 190-200 when I climb the dirt road to my house (1000 ft in 2 miles). But it's not hot here yet.
I had to increase the size of the hole in the bottom of the original radiator mounting frame so I could still use the petcock, plus I had to extend the petcock using a brass extension. I prefer this so I don't have to remove the lower hose to simply drain the coolant, although some prefer not to have a petcock so it doesn't get trail damaged. Good fit otherwise.
I was running the stock size alum rad from Man-A-Fre, Did NOT work for me. Could not keep my V8 cool with a mech fan with shroud, and an electric pusher fan. Had to go to a larger rad to keep it cool... Granted, it is much warmer here then in S.D.
Now running a larger rad, mech fan and NO shroud at the current time, it stays cool...
Shawn
Soo would you run this aluminum 3 row or a OEM style 4 row??
In a V8 application, neither... In a stock setup and the $$ allowed, the Alum.
Shawn
I have that radiator with a pusher fan and a mechanical fan behind. Works okay. I am having some heating issues but I think it is a thermostat or something. It should not be running as hot as it is right now.
I bought the 3 row from Champion. I wont be ready to fire up for a few more months. Fitment was perfect.
