Yeah, you know the bolt I speak of. The bolt that has broken many of men. The same bolt that inspired some redneck to use the frame of his car to crack the bolt as he turned over the ignition. I'm pretty sure the word "f
k" was named after this bolt.
But it was this night. This Friday the 13th, that I wasn't broken by this bolt. In fact, it was I who did the crackin, and I didn't even move the pulley a Milimeter.
The best part about this is I barely used any effort and I didn't even have the tools that would be ideal.
I had a 1/2" socket wrench, torque wrench, 1/2 chain wrench, and a 3 1/2 ft cheat pipe.
At first I tried to fight the bolts fight. It showed me my upper body strength sucks and I got a weak stand up game. So, I did what I had to and I took the fight to the ground.
I latched the chain wrench around that pulley and attached my socket wrench. I added the cheater bar addition and wedged the bar down by the battery. I then put my 22mm on the torque wrench, wrapped it on that big ass bolt, and angled the wrench at 12 o clock. I then used a 5 gallon bucket to climb up in the engine bay. A stool will also work to give you a boost. Or if you are really limber then you can skip the bucket /stool entirely. I then sat on my fender with the cheater bar wedged under my right leg which was rested upon the manifold. I then used my other foot to push the torque wrench away from me.
I had that bolt tappin so quick with minimal effort. You shoulda seen it!
Winner by submission in the very first round......!!
k" was named after this bolt.But it was this night. This Friday the 13th, that I wasn't broken by this bolt. In fact, it was I who did the crackin, and I didn't even move the pulley a Milimeter.
