dogdaysindurham
SILVER Star
Got my TJM Sump and Transmission Guard from Dirty Parts. It's been really hard to find pictures of them on the net. Might drill some more holes for venting.
I don't do hardcore wheeling, but just wanted more protection when I go camping / beach driving out at the Outer Banks. Plus the dealer broke the middle plate and left it off / not telling me.
Maybe Wilsil can comment on the TJM robustness.
I think Slee plates are 3/16 in (so 4.76 mm). Not sure how think the AFIK plates are, I think they are aluminum but 5 or 6 mm in thickness. Those might be better for hardcore wheeling.
Do you just need these 2 to protect the whole underneath? Seems worth a try for $200 and offers more protection than stock.
They are cheap enough to buy two of each and just double up![]()
Ya that was me. I forgot to get around to it. I think I have a few pics. I'll see if I can get them up today. I drilled a couple new holes for mounting. Elongated a couple existing ones and drilled some new access holes for the oil drain plug and zerk fittings. It's pretty obvious what you need to do if you install them.
It's definitely better than stock and obviously not as good as the SLEE. It functions perfectly for my needs. Powdercoat is holding up fine but it's a skidplate so I couldn't really care anyway.
The front of the tranny plate sits on top of the front skid. They overlap quite a bit and then bolt to each other. Carl posted pics in the vendor section.
Correction: I see he didn't actually post any with the tranny guard installed. Give me an hour or so and I'll post up some pics.
