We use the Caswell Copy Cad kit....1.5 gallon setup. I bought it a few months ago and have run thru quite a bit of hardware. I bought the power supply on Amazon as well as a agitation pump and aquarium heater. It's easy and actually pretty enjoyable process to do but the key is in prep....like with everything else. We clean the parts in our ultrasonic cleaner. Then they go into the bead blast cabinet(120 grit aluminum oxide). The key step if you want shiny parts is they need to be polished with a wire wheel on a bench grinder. One final clean in an acetone bath then they get wired up and dipped. There was a slight learning curve for a few things like the polishing with the wire wheel(we were just vapor honing after bead blasting). That was about it. Chemicals all remain stable when stored it seems. Easy to setup when we need it. Lots of good videos to learn from....I kind of took a little from each one and applied it to our process.
I mainly bought this so we could do small batches....we have a plater that will do all the hardware at once but sorting them all out and organizing didn't appeal to me plus things can get lost. Way better to do small batches for us since we usually tackle a certain stage of a build at one time(engine, chassis, interior). This is great for that.
Maybe one of the most satisfying jobs around the shop. Take a dirty old pile of metal and make it new.
We use the Caswell blue chromate for the silver parts....gives them a really cool look. Our next batch will be some of the black chromate I think.
